Hard Stuff in Shower Drain
Old 07-03-00, 06:10 AM
Guest
Question
Just bought a new (used) house. Shower drain running a little slow. Turns out there is hard, gritty white stuff on the walls of the drain and reducing the diameter at the water line by about two-thirds. Guy at Home Depot recommended acid based toilet cleaner. No change. Afraid to try to chip it free for fear of either cracking the plastic pipe or clogging it up. Any ideas?
Old 07-03-00, 07:48 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
quote:<HR>Originally posted by New Owner:
Just bought a new (used) house. Shower drain running a little slow. Turns out there is hard, gritty white stuff on the walls of the drain and reducing the diameter at the water line by about two-thirds. Guy at Home Depot recommended acid based toilet cleaner. No change. Afraid to try to chip it free for fear of either cracking the plastic pipe or clogging it up. Any ideas?<HR>
Probably hard water viniger should dessolve this.
Best Regards Plumber2000
Now with Human Click
www.atozplumbing.com
