boarding up a sink
Old 09-12-08, 02:15 PM
boarding up a sink
I have a sink in an alcove. I intend to close in the alcove. I will remove the p trap and seal that up. Can I just leave the valves on the pipe to the sink in the off position or should I remove the valves and cap off the copper pipe? I will sheetrock over the opening.
Thanks
Mikeman
Old 09-12-08, 05:13 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
I would remove the valves and sweat on caps. I did my first copper sweat/solder job for my new shower, and it was not that difficult. Leaving the valves could be bad, especially if they fail.
Old 09-13-08, 07:45 PM
plumbingods's Avatar
Capping it off is your safest bet.
If you choose to leave the valves on, you should still cap those lines after the valves.
