Disassemble valve before sweating it?
Old 07-26-00, 09:59 AM
Guest
Post
I soldered a new brass stop valve to 3/4 copper pipe and now the new valve has a pinpoint leak at the 2 inch diameter seam where you access the washer for replacement. Not at the stem nut.
I DID have the valve in the open position when sweating it. I did NOT protect any part of the valve or stem with a heat sink while soldering, ya know, like a wet rag wrapped around the stem.
Should I have disassembled the valve stem from the valve BEFORE I soldered it?
Why is it leaking at this threaded seam? I could understand if the stem nut leaked due to overheated packing, but I don't think there is anything at this seam that can be ruined by soldering. It is just a brass threaded top of the valve body.
Mark
Old 07-26-00, 03:07 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
Mark,
The valve could have been defective, if you can get the entire valve apart without breaking the pipes and get a valve like it, just replace the guts, if not, time to redo it.
Best Regards Plumber2000
www.atozplumbing.com
Old 07-27-00, 10:31 AM
Guest
Smile
I'll take that as good advice and plan on replacing the valve. Thanks for the extra point of view.
Mark
