leaky toilet
I'm baffled. I've replaced overflow valves twice and the flush assembly once, tried 3 different flappers, even gently fine sanded the flapper seat and get the same result, a slow leak into the bowl, resulting in the ball dropping, valve opening and water refilling the loss for a couple seconds.
Dave there is a tube that goes from the fill valve to the ovefill tube, make sure this is not below to full line in the tank.
Best Regards Plumber2000
www.atozplumbing.com
