help pvc pipe to low
Pedastal tower base is solid on the bottom. Now I am unable to connect the pvc pipe from the wall to the drain from the basin. The pipe from the wall is curved down then curves up to the pipe coming down from the drain connected to the basin. I've tried moving the tower backward but then I can't connect the faucet because it's to far from the hot and cold water connections.
Received 1 Upvote
1 Post
You have a choice. Replumb the drain line so that the trap (curved pipe) fits up under the drain tailpiece of the sink, or get new flexible supply hoses (they come in different lengths) to reach your faucet connections. You should be able to find either parts easily. Just know the measurements of what you're trying to do, and ask them to help get you the right parts.Good Luck!
