New Plumbing
Old 08-23-00, 04:42 PM
Guest
Question
When adding a new bathroom, should the concrete foundation be jack hammered in order to run the new pipes. We are remodeling and are hesitant about disturbing our foundation. Please reply with any comments.
Thanks,
Shari
Old 08-23-00, 04:56 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
Can you not tie the new plumbing into the existing plumbing?
If not adding a new hole through your foundation should not effect it, unless your removing alot more then that is required to be removed.
Best regards Plumber2000
www.atozplumbing.com
Old 08-23-00, 05:26 PM
Guest
Post
We are tearing down a wall between 2 bedrooms. The bath will be located in an area that has no plumbing in the foundation. Our existing bathroom is the room next to this new bath so the farthest distance we will have to go to tie into our plumbing will be around 7 feet. You think we should disturb the foundation or build up the floor?
Old 08-23-00, 10:50 PM
Post
knocking a 6" hole through the foundation should work, and should not hurt the structure.
Best Regards Plumber2000
Old 08-24-00, 08:22 AM
Guest
Smile
Thanks for your help.
