I'm holding my plumber's putty in my hand,
and on the reverse side it states that plumber's putty is NOT recommended for mar-
ble. Instead, tub and tile caulk should be used. I hope this answer will suffice.
Can an electric water heater that goes out / bad, cause an excessive amount of electricity to be used by the water heater? Also, when I turn on the faucets to the hot water side, there isn't any water pressure. Is there a water pump inside the water heater? Thanks for you help.Read More
