brownish hot water
Old 08-28-00, 09:25 AM
Guest
Post
Please help!
Last night we cleared up the main drain. However, when we turn on the hot water, brownish hot water kept on flowing. I left it running for at least 30 minutes, but no luck. The cold water is clear but not the hot water. I looked at the hot water boiler and it does not indicate anything wrong. What can I do? Any help is appreciated. Thank you!
[This message has been edited by Ms. Lam (edited August 28, 2000).]
Old 08-28-00, 07:26 PM
Plumber2000's Avatar
Post
It could be the inside of the tank is rusting away, and you will need to get it replaced soon.
Best Regards Plumber2000
www.atozplumbing.com
Old 08-29-00, 03:48 PM
Guest
Smile
Normally the hot water is fine. And another
question. How often am I suppose to drain some of the water out of the boiler and clear the main drain?
Thank you very much Plumber2000.
<HR>
