Kitchen disposal is seized. What to do?
Old 08-29-00, 06:08 PM
Guest
Unhappy
Our Mainline 2600 garbage disposal in the kitchen sink (five yrs. old) refuses to budge! There does not appear to be anything stuck in it. I have no instructional sheet. There does not appear to be anywhere to stick an Allen wrench or a reverse button. We get the "hum" that shows electricity is going into it, but that's all. There is a red button on side of it . . . but doesn't do anything when you hit it. What to do here . . . don't want to have to buy a new one yet! Am I risking my sanity if I unscrew the whole appliance from under my sink?
Robbie
Old 08-29-00, 08:26 PM
Pete
Post
Hi. It's probably just jammed up. Try taking a big stick or similar wooden item and stick it down into the opening in the disposal, pry around in there until you get some movement. Do this with the switch off of course. If you can get the thing to rotate it should work. If it still just hums it's probably time for a new disposal. Hope this helps!
Old 08-30-00, 02:30 PM
sprky
Post
hello robbie,
im sending this post over to the plumbing section, thy r better quilified to help u on this. look 4 further posts there
Old 08-30-00, 04:28 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
Robbie
<HR>
I like to take a basin wrench and use it to grab one of the propellars inside of the disposal to help umjam it. This way use have a way to twist the insides around in circles.
This works everytime for me, beats using the broom handle trick.
Best Regards Plumber2000
ww.atozplumbing.com
[This message has been edited by Plumber2000 (edited August 30, 2000).]
Old 08-31-00, 11:15 AM
Guest
Post
Are you sure there isn't an allen wrench socket on the bottom of the disposal?
Old 08-31-00, 01:46 PM
Post
quote:<HR>Originally posted by John Nelson:
Are you sure there isn't an allen wrench socket on the bottom of the disposal?<HR>
Believe it or not, yes there are disposals out there that do not have the place to insert the disposal wrench, for unjamming them.
www.atozplumbing.com
Old 08-31-00, 09:11 PM
L
Received 1 Upvote on 1 Post
Post
True enough, not all dispsals have an allen wrench socket for clearing jambs. But before you attack the jamb from the top, LOOK under the disposal. Dead center on the bottom you MAY find a place to insert the allen wrench and be able to clear the jamb from there.
<HR>
