Shower Drain
I have a crack in the shower drain about 2 feet long. i want to replace this section of the pipe. the pipe appears to be older black metal pipe. they are joined together with the smaller end going into a wider end and a rubber seal around it. how do i take these apart so as to replace just the section needed. any ideas??
Is there metal bands around the rubber coupling? Loosen these up, cut out the bad section of pipe and install a new section, you may need a second rubber coupling for the other end of the pipe you cut out.
Best Regards Plumber2000
www.atozplumbing.com
