Drum Trap
Old 09-08-00, 09:43 AM
Guest
Post
What is the purpose of a drum trap and how do you replace the drum trap cover?
Old 09-08-00, 12:33 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
A drum trap is just a different type of trap the was used often in the old days, there still in use today also. The cover is a standard 3" plug, standard thread, you can use a 3" clean out plug for it, just make sure the threads are clean, plastic threads are easy to cross if your not careful.
I mysef would just replace the entire trap with a standard trap.
Best Regards Plumber2000
www.atozplumbing.com
Old 07-28-08, 06:58 AM
L
Hold the PHONE JACK!
You can't just replace a drum trap with a standard P trap!!!!
The reason for this is that most drum traps in older homes are NOT VENTED.
If you want to replace a drum trap with a p trap, first you must insure that the drain is properly vented.
Drum traps will not siphon all the water out when not vented.
P traps can have all the water siponed out when not vented.
Do not, I repeat Do not replace with a p trap UNLESS the drain is properly vented.
The best would be to install a vent and a p trap, but this could be pretty expensive.
Larry
Old 07-28-08, 07:30 AM
plumbingods's Avatar
Unfortunately, there are still drum traps (PVC) on the market for replacement use only. They are no longer allowed by code.
I agree that replacing the drum trap with a standard P-trap is not always a good idea, but it is a situation call. You would need to take all the plumbing into affect.
You could also replace the drum trap with a p-trap, and if you cannot run a vent into the attic, you could use an AAV (Air Intermittance Valve) in place of a conventional vent. But it must be accessible for replacement from time to time.
Old 07-28-08, 02:41 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
This thread is 8 years old....
Old 07-28-08, 03:17 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Could be a new record...lol
Old 07-28-08, 03:21 PM
It's very close.............................
Old 07-28-08, 03:32 PM
Wow ! I must have been sleeping. I do look for that usually.
Old 07-28-08, 04:03 PM
Mark,
Happens to me sometimes.....don't sweat it.
