annoying leak
Old 09-16-00, 05:46 AM
Guest
Post
My cental a/c drain pipe is connected to the bathroom sink pipe.There is a leak coming from the a/c pipe where it connects to the bathroom sink pipe.How can I fix the problem?I have tried applyng goop to no avail.Help!
Old 09-16-00, 06:52 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
What type of pipe (pvc white plastic)? How is it connected (glued or threaded fitting)? What kind of "goop" have you tried to seal it with? Need a little more info.
Old 09-16-00, 07:34 AM
Guest
Post
Old guy,thank you for trying to help.The pipe is white pvc plastic.The pipes are glued and the type of goop is
plumber's goop adhesive and sealant.
Old 09-16-00, 07:59 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
Mary,
How is this attached to the sink drain?
Is it connected by a tailpiece? Before or after the trap?
Best Regards Plumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited September 16, 2000).]
Old 09-16-00, 10:25 AM
Guest
Post
Pardon my ignorance but where is the trap located and what does a tailpipe look like?If you give me a description of both things then maybe I could give you an answer.Thanks again.
Old 09-16-00, 02:57 PM
Cool
The trap is the U-shaped part of the drain that holds (traps) water to prevent sewer gases from leaking back up into the room. A tailpiece is the pipe that goes from the drain of the sink to the trap. The tailpiece may be one like is used to attach a dishwasher hose, which will have a smaller pipe out of the side (which is probably what you have.)
Since this is seems to be leaking at a pvc glued connection, and as a drain it has no pressure....clean off and dry the connection good where it's leaking and then swab on pvc glue around the outside fitting edges and let it dry. That will probably stop it. Good Luck!
