Excessive water pressure
Old 09-25-00, 10:50 AM
Guest
Post
The water pressure in bathroom sinks seems abnormally forceful. The fixture is the pull-out single knob style (which is somewhat difficult to control anyway) and is just too difficult to regulate to the more moderate flows. Before I consider replacement, I'm wondering if I have alternatives - different washers or some kind of correction in the plumbing itself. I take a bath everytime I turn it on....Water pressure elsewhere in the home is normal. Thanks!
Old 09-25-00, 11:07 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
Try a areator that will only allow so much water the pass by, like one that will only allow 2.5 gal per minute. see if that helps you out.
Best Regards Plumber2000
www.atozplumbing.com
