ice maker water line leak
Old 09-28-00, 07:48 AM
E
Post
I have copper tubing from fridge to valve.
I have tightened nut but water still leaks around nut and valve connection.
Should I just buy a new nut or should I buy a tube cutting tool, cut the line off a little and install the new nut? Should I replace the valve also?
Thanks,
emsandsas
Old 09-28-00, 08:27 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
Cut the nut off and install a new nut and ferrell, when tighting this up, go 1/2 to 3/4 of a turn past snug, then test, if still leaks then tighten till you see it stop, do not over tighten.
Best Regards Plumber2000
www.atozplumbing,com
Old 09-29-00, 06:20 AM
E
Smile
Plumber2000,
Thanks for the reply.
emsandsas
