Rocking Toilet
Would like to know how to fix a rocking toilet. It seems that the floor is slightly warped causing it to rock from side to side. No amount of tightening will stop the rocking. Would appreciate any helpful advice.
Thanks in advance.
Thanks in advance.
quote:<HR>Originally posted by jjohnson@nckcn.com:
Try shimming with plastic shims to sturdy it.
Also you may need to check the flange to see if its connected solidly to the floor.
Good luck
plumber john<HR>
Thanks John. I verified that the flange is connected well and the shim worked fine. You have been a great help!
