All toilets have phantom flush
Old 09-17-00, 10:15 AM
Guest
Post
HELP!!! I have 3 toilets in my house and they all started on the same day to run for about 5-10 seconds every 1/2 and hour or so. The only thing that has changes is my girlfriend placed one of those white tablet bleach smelling things into the tank where the flapper and float are. What could be the problem and why would they all start at the same time? HELP!!!
Terribly confused homeowner.
Old 09-17-00, 10:54 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Post
You just answered your own question, bleach tablets will do a number to unprotected rubber flappers, install new flapper and remove those tablets. If you are going to use the tablets get the treated flappers that will resist chemicals, there red in color, and made by Korky. I have seen those tablets change the color of these flappers, so you get an idea how strong those tablets can be.
Best Regards Plumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited September 17, 2000).]
Old 09-17-00, 01:06 PM
Guest
Post
Another stupid question, how do I replace the
flappers? Thanks.
Old 09-17-00, 02:20 PM
Post
Remove one of the old flappers and see how it comes off of there, there easy to figure out, most will attach to the ears on the side of the center flush valve, then just ajust the chain, where there is a tiny bit of slack between the handle and the flapper.
Old 10-05-00, 12:37 PM
Guest
Question
what if you already replaced the flapper and it still has that "phatom flush"
Old 10-05-00, 04:55 PM
Post
Then it's possible the fill tube that runs to the overflow tube from the fill valve, if it's below the full water level of the tank, it will siphon the tank water out, causing the fill valve to cycle on and off all the time.
