Removing valve
I have a valve I need to replace due to a leak in it. My problem is how to properly remove it. Can I just simply heat it up to loosen the connections and remove it or do I need to do some cutting?
Is this a solder on, compression type, or thread on type, ball or gate valve, where is it located, what does it go to?
Best Regards Plumber2000
www.atozplumbing.com
