Rough in specs for double sink in bathroom ?
Old 11-10-08, 07:12 AM
R
I will try this in a new spot! I would like to know the rough-in specs for a 60 inch double vanity sink. Both the supply lines and drain lines? Does the sinks share a drain and supply lines?
Old 11-10-08, 07:44 AM
H
Yes
Typically,,,rough from the floor is drain 16" +- depending on the sink depth,,,,and 20" on the supply.
1 1/2" drains sched 40,,,,,1/2" cpvc supply......
If you have drawers between the two sinks, make sure you pipe near the rear of the vanity....the drawers should be shorter than the wall......some folks prefer to make the joints in the framing and stub out directly behind the sinks so it looks very clean....
Old 11-10-08, 08:06 AM
R
Hey thanks! Now do I just run one vent up at the far end of the sinks drain?
Old 11-10-08, 08:18 AM
R
and one more question--if I do put the drains in the wall, where do I install them? Horizonally for a 60 inche double sink? 18 inches from each end ?
Old 11-10-08, 07:10 PM
H
Yes....just make sure you slope them toward the drain....1/4" per ft is enough.
also, your closest vent (2") shouldn't exceed 5' from the drain pipe.
Old 11-11-08, 05:42 AM
R
Thanks for the help! this awnsered the question !
