Please check my kitchen sink drain plumbing
Old 11-21-08, 09:55 PM
I have just dry fitted a drain for a new kitchen sink. Please look at the attached photos and send your suggestions. I want to make sure I have things right before I glue.
Some notes:
-the sink on the right is much smaller and less deep than the sink on the left
-in the left, just before the system goes into the wall, I have added a vent and a clean-out
-there is a dishwasher drain in the run between the two sinks
-please keep in mind that it loosly dry fitted, so everything will be tightened up
Thank you for your help and suggestions.
Old 11-21-08, 10:59 PM
steve_gro's Avatar
Well for one, turn vent wye around.
Old 11-22-08, 06:22 AM
Received 10 Votes on 9 Posts
Turn the vent wye around? Wye? Why???
Old 11-22-08, 06:53 AM
I would think you'd want the outlet of the wye facing opposite of the water flow direction.
Dishwasher drains are usually placed in the tailpeice coming down from a sink basket.It's a specifically designed part.In this case it would have to be on the small side.I'm not sure it actually matters here but that's where they usually are placed.
Old 11-22-08, 12:06 PM
steve_gro's Avatar
You want the sweep of the vent wye to point in the same direction as the drain. For one, it might get some water down it (if it's a real vent & not an AAV). And if there's a blockage beyond the vent wye, things can get caught in it that would be hard to clear later on. The air movement (bi-directional in a real vent and one-way in an AAV) will not have any trouble turning the corner.
http://tbn0.google.com/images?q=tbn:...n-fitting1.bmp
HTML code is On
