Shower pipes
Old 11-04-00, 04:46 PM
Guest
Red face
How do you clean out the pipe(s) that run(s) between the showerhead and the tub faucet?
Old 11-04-00, 06:09 PM
L
Received 1 Upvote on 1 Post
Post
There is only one pipe that rises from the valve to the drop-earred elbow where the shower arm screws in. "Cleaning" it is pretty much out of the question. If it is old galvanized and full of corrosion, replace it. But be aware, that will involve opening up the wall from one side or the other so you can get to it!
Old 11-05-00, 04:49 AM
Guest
Post
Thanks for the response.
Old 11-05-00, 06:22 AM
Mike Swearingen's Avatar
Cool
I'm not a plumber, but if your question is prompted by poor water pressure, try removing your showerhead and cleaning IT out, first, and soak it in vinegar overnight to dissolve hardened minerals.
Run the shower without the head on it to flush line and check pressure/volume. If that is normal, and cleaning the showerhead did not help, just replace the showerhead.
Otherwise, you'll have to replace the pipe, if it's galvanized.
Good Luck!
Old 11-05-00, 07:33 AM
Guest
Post
Thanks, but the problem is not water pressure, it's gunk coming out of the tub faucet. I though maybe it was from the pipe running to the shower head; but apparently not.
Old 11-06-00, 05:21 AM
Cool
Water goes to your tub faucet first, then up to the showerhead by diverter.
If you're getting gunk out of the tub faucet, then that means replacing those galvanized supply lines as lefty said.
Good Luck!
Old 11-06-00, 09:59 AM
Guest
Post
Should this happen in a two-year-old house?
Old 11-06-00, 02:04 PM
Cool
A 2-year-old house? Absolutely not, and I bet that you don't have galvanized pipes, either.
That gunk could be coming from your water heater. Have you ever flushed the tank?
Old 11-06-00, 02:20 PM
Post
Collect the gunk and figure out what it is. Describe it to us and we'll guess.
Old 11-06-00, 03:09 PM
Guest
Post
No I have never flushed the hot water tank. How often should that be done?
Collect the gunk? OK, I'll report back.
