Toliet Flapper
Everytime the toliet is flushed the handle must be held or the flapper will close. Adjusting the chain causes similar problems.
Or you could make a float.
Get a piece of dense foam (styrofoam - but has a spongey look and feel) about the size of a silver dollar and about 3/4 in. thick.
Cut a slit halfway thru (a radius cut). Slide the chain that goes from the handle to the flapper into the slit, about 1 1/2 in. above the flapper.
This will add floatation to the flapper for just a little longer than it has now, creating a longer flush. (They might even sell these floats at the home center. I've seen them on a lot of new toilets).
[This message has been edited by Plumber2000 (edited November 03, 2000).]
<HR>
Why would you want to mess around trying to make a float for a dead flapper, installing a new one is a better way to do it. There cheap and easy to install.
Best Regards Plumber2000
www.atozplumbing.com
Because a dead flapper usually leaks. It doesn't usually stop floating.
If it's a few years old tho', P2000 could be right. Inspect it. If it looks warped or a lot of black stuff comes off it when you rub your finger on the seating surface, replace it. If this is a fairly new fixture, a new flapper may not float any better than the old one. Hence, a float.
Abnormal
Abnormal
