Toilet won't flush{not clogged}
Old 11-09-00, 06:20 PM
Guest
Post
I unbolted comode,took it outside,filled it
w/water and it flushes fine.I poured a 5 gal
bucket of water down the drain pipe, w/no
back up.When I put the comode back in place
it still won't flush.This happens whenever we
get alot of rain.any ideas??? thanks
Old 11-09-00, 08:06 PM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Upvotes on 4 Posts
Post
Hi:JMB
I am not a plummer but it sounds like your problem is a restricted or clogged roof air vent pipe.
If your able, climb on the roof and run a snake down the air vent line as far as it will go. You can then test it from up there if you have a garden hose that will reach up there.
Run some water down the line after clearing it with the snake and see if any of this helps. Be a good idea to have a helper stand by, at the toilet, just in case the water you run down the vent pipe backs up into the toilet.
Good Luck,
TomBartco
Old 11-10-00, 07:09 AM
Received 1 Upvote on 1 Post
Post
If it's not the drain, and it's not the toilet, the vent is the only thing left. The 5 gallon bucket you poured down the drain was probably not a realistic test, because it doesn't simulate the rate at which the toilet puts water down the drain, and because the open pipe is self vented.
Go with Tom's advice.
