problem replacing faucet
Old 11-18-00, 11:16 AM
Guest
Question
I am curently trying to replace old faucets in my home. I feel I have properly installed a new one, but for some reason when I turn the water back on under the sink, it comes out the faucet for a second or 2 then stops. I can hear the water coming up through the pipes, and even took the faucet off to check to see if the water is there and it is. I just cannot get it to come out of the faucet.
Any sugestions?
Old 11-18-00, 11:41 AM
Mike Swearingen's Avatar
Cool
FAQ. Answer is that when plumbing around faucets, you usually dislodge a litle debris that clogs up the faucet aerators. Remove and clean aerators. Flush faucet before re-installing.
Good Luck!
HTML code is On
