toilet make loud whining noise when filling
Please help, After I replace the inside parts to our toilet it makes a loud whinning noise when it is filling. It can be heard throughout the house. Any help would be great.
Are you sure the shut off valve is open completely? The problem is a restriction someplace in the water line. A kinked or partially blocked supply line could be the problem, or it could be a restriction at the base of the fill valve.
Brother,
Check you head-space at the Cloggins valve.
The smilee could be caught at the pyloric valve. Or better yet, check to see if you head is up your forth point-of-contact.
Just checking the site as you suggested, saw your post and couldn't resist.
CYA
CYA
