Knocking Pipes
Old 11-24-00, 10:52 AM
Guest
Post
There is a Steady knocking from a copper pipe in my basement.I've isolated the pipe thats knocking It ranges in how loud and rapid it knocks , the highest being the washer running midrange being the toilets
flushing to the lowest being the sinks that the pipe suplies. I've bled the air form the pipe with the valve locate about 2 feet away from where i can feel the vibrations
Old 11-24-00, 05:33 PM
Post
Are you on city water?
Does it knock all the time, or just when the water flow starts or stops?
This is probably classic water hammer, which is caused by pipes not properly secured. It is probably NOT caused by air in the pipes (how come everybody wants to blame everything on air in the pipes?).
Your choices are: (1) ignore the noise, (2) secure the pipes, or (3) install water hammer eliminators. I recommend (1).
HTML code is On
