Broken Shower Diverter Valve
Received 0 Votes
I'm replacing a diverter valve in a three valve shower/bath. The valves are american standard and the house is about 40 years old. I've bought the replacement stem, but the old stem is broken and half of the pieces are still in the valve body (vinyl end, diverter and probably one washer) I can't get these out. Does anyone have a suggestion?
Thanks
Thanks
Received 0 Votes
BEB,
Tried that with no luck. also tried needle-nose, nothing to grab; coat hanger through holes in fixture, did not budge; tapping with hammer to free up; same results. Have put the stem back in and adjusted to shower mode until I/someone think/s of something.
Thanks
Thanks
Received 0 Votes
Extraction Accomplished!
For the information of anyone with a similar problem, the solution was to spray with WD-40 (some sort of calcium or scale remover would probably have been better) then use a screw tap (or nipple extractor will work). Screw in the extractor then beat like he... ck. Worked like a champ for the diverter, but you should use caution on a hot/cold valve as the seat can more easily be damaged.
988
988
