Vent pipe sizing
Vent pipe sizing
Hi all,
Quick and easy question for you. I am designing the plumbing system for a small remodel and cannot find drainage unit values for a Washing machine.
I have a sink, shower and washing machine sharing a vent pipe. Each will have 1 1/2 inch lines to where they all connect together, but can I get away with 1 1/2 inch all the way to the main vent stack?
The main connection is only about 12 feet away (5 vertical, 7 Horizontal).
Thanks
(toilet is on a separate vent)
Thanks
Hi Justin,
According to my info, which is IPC 2006, you will need a 2" drain for those 3 items with a total of 5 DFU's. (w/m = 2 dfu's) with a minimum vent of 1 1/2".
All vents must be a minimum of 1/2 the diameter of the drain it serves.
Remember, I do not know the code book you go by, so if you are unsure, call your local town building official.
