Musty or sewer gas smell in one Bathroom
Old 01-19-09, 08:58 PM
D
We just eliminated our septic tanks and hooked up to the city sewer system two weeks ago. We have 3 bathrooms, 2 up and 1 down. Ever since we hooked up to the city sewer we are getting a musty, sewer gas smell from one of the upstairs bathrooms that has a shower.
I don't understand why only one bathroom. Can anyone help solve this problem?
Old 01-19-09, 09:08 PM
plumbermandan's Avatar
either the shower is not used often and the trap is dry or the smell is coming from under the toielt, ie. a bad wax seal
Old 01-20-09, 07:46 AM
D
Funny Thing Plumbermandan!
We didn't notice the smell while on septic prior to hooking up to the sewer. Wonder why the change all of a sudden?
Old 01-20-09, 07:15 PM
plumbingods's Avatar
I would think that it is a wax seal problem, unless you have a drain that does not get used very often.
You see, once you are connected to a city sewer line, you can get positive pressures as well as negative pressures in the pipes. If you have a bad wax seal; unused drain, or a crack in a pipe, there could be a positive pressure pushing the smell out from the problem area. On a septic system, it is very rare to have a positive pressure.
You may also have a vent issue which is making it hard for a positive pressure to leave the system.
Old 01-21-09, 10:51 AM
O
Received 1 Upvote on 1 Post
We had to pull a toilet here at work a short while back and I was amazed at the amount of air coming up the sewer pipe and the force that it was coming out. Never seen it before till then.
