Galvinized pipe fittings for Natural Gas???
Old 01-21-09, 05:34 AM
Is it acceptable to use galv. pipe fittings for a gas line?
All the pipe fitting I have ever done for gas has been black. Its just what we use, but I have some galv. fittings here at the house. If its OK to use them w/ gas then it will save me from buying new. (from the supply house as Big Boxes only carry cheap China fittings which I don't want in my home gas system!)
I thought I had heard something in the past about not mixing galv. fittings w/ nat. gas. Any body have any idea?
Old 01-21-09, 07:59 AM
plumbermandan's Avatar
it is the exact same pipe but one has a specia coating. nothing against it is the codes i know of
Old 01-21-09, 11:29 AM
Talking w/ my buddy at work....
Right, its the same pipe and can be used in a gas line BUT...
The galv. coating could flake off and clog up your gas works.
So I guess I'll be buying some new black fittings!
Old 01-21-09, 01:35 PM
C
I know that in NY, even the Gas Crews use only black pipe when installing a service. Take a look around, and I'll bet you'll see rusty pipes on both sides of the gase meter.
Old 01-21-09, 02:12 PM
shacko's Avatar
Galv. on gas pipe
Milemaker13: There are many jurisdictions in the US that allow galv. on gas pipe, unless you are getting a permit I would use it. If you call your local code office, they may allow it also.Beer 4U2
Old 01-21-09, 05:56 PM
i have never heard that. since gas into a house is normally ounces and water pressure is pounds i would think that isnt a problem and i have never incountered it
HTML code is On
