Pipes knock when tolet flushes
When ever the tolet flushes there is a loud knock of the pipes in the basement as soon as the tolet stops filling. If I turn on the bathroom sink prior to the filling the knock does not occur but as a soon as the fill completes there is a rush of air at the sink. Also when the knock occurs there is a sight discharge of water from the pressure relief valve connencted to the tankless hot water heater. The home has a boiler which is less than 2 years old and there is no air in the system. The bathroom on the second floor does not have this problem. I have changed out the fill tube with no success. Everbody I have talked to is puzzled. Any help is appreciated.
**************Beer 4U2*****************
Banging Pipes
rferenc: If you are getting banging pipes and water comming out of the relief valve its a good chance yoour water pressure is too high, get a pressure gage and check the incomming pressure, it should run approx. 60lbs, 80lbs is usually code max.
If it is more than 80lbs you will need a pressure reducing valve, luck
Another thing to look at is, what kind of hot water do you have? If it has a tank type and you are on city water, you may need a thermal expansion tan installed or replaced. Without this tank in certain situations will cause a high, sometimes extremely high water pressures in your water piping. This high pressure can cause the relief valve to drip or blow off if pressure gets too high.
I would take a pressure reading of your water system and possibly need to install a pressure reducing valve as stated earlier. You may also wish to add some watter hammer arresters in the system.
