Another Toilet Bowl Question.....
Old 02-02-09, 06:01 AM
Well I got the toilet bowl installed, no leaks. For some reason when using(sitting) the toilet, every now and then, the water will run in the tank for a split second. Any thoughts? Everything seems to be nice and tight. THANKS!
Old 02-02-09, 11:22 AM
plumbermandan's Avatar
you probably need a new flapper valve
Old 02-02-09, 11:38 AM
It seems the problem was a high water level in the tank that was going over the overflow tube. Situation resolved.
HTML code is On
