How to remove broken male pipe inside female pipe??
Old 03-01-09, 02:37 PM
In replacing showerhead, the pipe broke off and part of the threads are still inside the female. I have tried an internal nipple wrench - to no avail. It won't break it loose. I would like to remove the remaining male section w/o having to cut into drywall. Please help!!
Old 03-01-09, 04:37 PM
steve_gro's Avatar
See if you can locate an 'easy-out' at a hardware or auto parts store. Worst case, take a small hacksaw blade & carefully cut through the remaining male threads (w/o cutting the fitting they're in) and tap/fold it over with a screwdriver.
BTW, all the broken shower arms I've come across have been made of plastic.
Old 03-01-09, 06:32 PM
Thanks Steve
I will try to find an Easy Out tomorrow and give it a try.
Old 03-02-09, 07:35 AM
plumbermandan's Avatar
cutting the piece out is probably gonna be what you have to do
i have seen many metal shoer pipes break when they are very old and had hardening pipe dope used on them
HTML code is On
