Digging a hole in a concrete foundation
Old 03-26-09, 12:50 PM
L
Question Digging a hole in a concrete foundation
Hi,
I've heard that digging a hole in the foundation is not a good idea, as there are some tension wires that can be broken in the foundation. Making any holes would need to be done by foundation experts.
Thank you, LadySavingMoney
Last edited by LadySavingMoney; 03-26-09 at 01:43 PM. Reason: What to make clear my concern
Old 03-29-09, 05:32 PM
Z
Received 206 Votes on 184 Posts
Most foundations are poured with simple rebar or steel mesh. Cutting a trench will not affect the structure of the house or the slab.
There are some foundations which use tensioned wires... if you're "lucky" enough to have a slab like this, you do need to be careful to not cut through the tension cables.
Do you know that you have one of these slabs/foundations?
