Metal threads very tight, but still have a leak?
Old 04-10-09, 12:55 PM
I have connected two metal pipe threads together for my water supply. I used some teflon tape, and the threads are as tight as I can get by hand, but there is still a small leak and water droplets coming through. What could I have done wrong? Should the teflon tape extend farther down past the threads? Should I not use teflon tape? Both of my water supplies leak, and although you can't see it, beneath the escutcheon where it connects to a brass thread, it is leaking there as well. Thanks for any help!
Old 04-10-09, 03:09 PM
ya more teflon tape... so bassically when you start to thread your fitting on.. you should be getting some resistance from the tape sealing the connection.. and also you should use a wrench to tighten more.. not just hand tight.. as water pressure can be high in places..
Old 04-10-09, 09:08 PM
plumbermandan's Avatar
you only need 3-4 wraps of teflon tape then a dab of teflon paste and more than hand tight
Old 04-11-09, 06:42 AM
You guys were right. I bought some extra thick teflon tape, wrapped it 3-4 times, and used teflon paste and wrench-tightened it and that worked. Thanks!
HTML code is On
