Help me ID the parts...(pics inside)
so i'm getting ready to swap some pipes (galv steel to copper) and just want to make sure i'm dealing with not going too far...
look like a steel pipe into a brass fitting? why is there an extra screw/clamp looking thing across the pipe?
side shot of the piece. can i unscrew the part that's above the meter (teflon tape part) and replace it w/ a brass 3/4 NPT to 3/4 copper sweat?
here's the other end of the steel pipe (similar looking fitting)..what's with the extra stuff that on the fitting? why wouldn't someone just screw the steel pipe right into the T fitting? dielectric fitting?
last thing...noticed this on the steel pipes. is it rusting from inside out?
sorry for the bandwidth..thanks for looking.
What you show measuring is a 1/2" fitting. but ideally, residential water supply lines should be min. 3/4, and remain 3/4 inside the house as close to the faucets as practical, before necking down to 1/2. If you are replacing it with new pipe, go to all 3/4 as far as you can, don't worry about what is there now. Even if you don't replace it all, it is easy to get fittings to adapt any size to any size.
plumber type guys;
what about the clamp on fitting?
op posted:
I'm curious as well but the OP asked about removing that fitting and being able to attach a threaded pipe directly to where the strap-on is attached.
any ideas?
op posted:
any ideas?
Received 38 Upvotes
I'm only 90% sure of this but I think the brass fitting is a compression-type coupling on an unthreaded piece of steel pipe. It uses a rubber washer or "O" ring to achieve the water tight seal and the clamp is for electrical bonding.
Since the water meter most likely belongs to the water utility it may be best for mktbully to first contact the utility before making any changes. If they okay it, then the brass adapter would be removed back to the brass valve. It looks like there is a nipple between the adapter and the valve.
