New toilet plumbing
Old 05-13-09, 05:10 AM
Location: I am adding an upstairs master bath in a small room connected to the master bedroom. There is a wet-wall containing plumbing for an existing upstairs bath and existing downstairs bath. The existing upstairs and downstairs toilets each have their own
New toilet plumbing
I am adding an upstairs master bath in a small room connected to the master bedroom. There is a wet-wall containing plumbing for an existing upstairs bath and existing downstairs bath. The existing upstairs and downstairs toilets each have their own wastepipes to the main drain in the crawlspace. Can a new toilet connection be added to the vented vertical wastewater pipe that serves the downstaires toilet or would this be a no-no? If not, can a 2-way toilet arrangement (one on each side of the wet-wall) be installed on the vented upstairs vertical wastepipe?
Old 05-13-09, 12:12 PM
plumbermandan's Avatar
no you can not drain fixtures from the second floor into the vent for the first floor.
yes you can tie the drain for the new bathroom into the drain for the old on the same level but you better make sure you know what the pipe is for
HTML code is On
