Cast iron pipe to PVC in venting
Old 07-13-09, 10:16 AM
Is it alright to replace a size of pipe by a smaller section to fit it in the wall so that I can have a flat wall while remodeling the bathroom?
Old 07-13-09, 02:51 PM
shacko's Avatar
Replacing Pipe
It depends on what pipe you are replacing and what it is hooked to, more info.
Old 07-19-09, 01:15 PM
It seems that the pipe is venting everthing in the house but I'm not sure. It is next to the toilet and the tub drain, plus there is another bathroom right under it with shower, sink, toilet, and washer. The cast iron pipe is set on top of a pvc pipe already and attached to it with a rubber gasket and clamps. Even if I could not reduce the size of the pipe, I would definitly replace it with a PVC pipe because of the weight.
Old 07-20-09, 01:59 PM
shacko's Avatar
If there are no fixtures above the point you're talking about you should be able to go one size smaller, but if anything is connected to it, leave it alone.
Old 07-27-09, 07:55 PM
Thank you for the info. No nothing is connected to the pipe from there to the roof.
Old 07-29-09, 04:06 PM
Received 19 Votes on 18 Posts
I believe there's a code stating that there has to be as much vent as there is drain, based on the cross-section area of all the vent pipes and the cross-section area of the main sewer drain. Usually, this means a 3" building drain requires a 3" vent. So downsizing the main stack may not be a good idea.
HTML code is On
