RustyPipes
Old 08-11-09, 04:01 PM
RustyPipes
Air in pipes. How do I remove air from plumbint pipes to stop the vibration in the pipe when I flush the toilet?
Old 08-11-09, 04:05 PM
There is a vibration in my plumbing pipe when I flush the toilet. How can I remove the air to correct this problem?
Old 08-11-09, 06:48 PM
Received 19 Votes on 18 Posts
Air in the supply pipes should bleed out after using the pipes for a day or a week. If the pipes are still rattling around, you likely have another problem.
1) They need to be strapped down tighter so they don't shake around and move.
2) You may have a worn washer in the toilet shutoff valve which is causing vibrations when water runs through the valve. Do the vibrations sound like a mini-jackhammer?
HTML code is On
