Toilet--cast iron pipe, replacing flange
Old 08-24-09, 07:03 AM
We are going to be reflooring a bathroom in an old house. The toilet plumbing is cast iron. We'll need to raise the closet bend & flange, as the sub-flooring will make the floor higher. I've heard there is some sort of insert that can do this without actually changing the existing plumbing. Could anyone tell me anything about this?
If not, what is the best way to remove the cast iron and replace with PVC?
Old 08-24-09, 07:10 PM
Received 28 Votes on 22 Posts
Spacer rings for toilet flanges are available and would be the easiest to use. You might have to go to a plumbing supply company to find them rather than the big box megamart homecenter.
HTML code is On
