AAV Placement Confusion
Old 09-25-09, 06:53 PM
Hello.
Remodeling a bathroom. Im confused about the placement of an air admittance valve. Here is the drawing I made of my plumbing layout.
http://i302.photobucket.com/albums/n...0/scan0001.jpg
As you can see I have two options. Vent in the dry line above the sink or vent in the wet line between the tub and sink. I have a Black and Decker plumbing book that shows a picture of an AAV between two fixtures in a basement in the wet line with the fixtures above the AAV.
Old 09-26-09, 07:28 AM
The correct link is...
http://i302.photobucket.com/albums/n...scan0001-1.jpg
The link in the first post was edited.
Old 09-26-09, 12:02 PM
shacko's Avatar
Unhappy Aav
If your diagram is close to what is actually there, why don't you run a real vent?, do you realize that AAVS' are mechanical devices that have to be exposed and they also can go bad?
I would never use one unless there was no possible way to install a real vent, your call.
Old 09-26-09, 01:48 PM
How would I go about running a regular vent in this situation?
Like this?
http://i302.photobucket.com/albums/n...0/scan0002.jpg
Old 09-27-09, 12:12 PM
shacko's Avatar
Smile Vent
I would run your 2in line to the tub area and take a 2in wye off before the trap, run the branch of the wye up for you sink, when you get thru the floor, add a clean-out, reduce to 1 1/2 for the sink, continue up and over and tie into your stack.
Old 09-27-09, 03:06 PM
Old 09-27-09, 11:56 PM
Yeah, Like that. You don't NEED the second cleanout, but it would never hurt!
HTML code is On
