Clogged Garage Floor Drain
Old 01-05-10, 10:26 AM
I recently purchased a home built in 1962 with a floor drain in the garage. The home is in Minneapolis, MN. Below the drain cover there is a 2" cast iron pipe that extends down about 2' and then there is a very hard blockage that almost feels like concrete. I tried a 1" steel snake, but that was useless. Water does drain very slowly, and handles incindental water from cars and snow, but I would like to wash cars inside and any higher volume of water causes it to back-up.
I have thought about renting a power auger to see if that could chew through the blockage, but I don't want to damage the piping.
Any thoughts?
Old 01-05-10, 10:45 AM
There should be a "P" trap at the bottom of that 2' tail piece that you are looking into. A 1" snake is too large to go through the trap. Try a small (1/4" to 3/8") snake.
Old 01-06-10, 05:35 AM
Lefty,
Last night I tried a smaller snake, and no luck. I think the blockage is before the p-trap.
Old 01-06-10, 04:02 PM
If the blockage is before the P-trap, you can use anything that will fir inside the pipe to dig it out. The P-trap is directly below the floor cover, how ever far down it may be to the top of the trap. (This is assuming that you have a P-trap.)
But do you have a DRUM TRAP under the floor??
I certainly wouldn't sent a power drain auger down the drain until you know FOR SURE what you are dealing with. A power snake will tear up a drum trap (if that's what's actually there), and you will have MAJOR problems.
Old 01-07-10, 06:06 AM
Since the blockage is down about 2' below the garage slab, I can't be sure what type of trap is down there. I really can't see with a flashlight. I am not familiar with Drum Traps, but after looking a few pictures on-line, this doesn't look typical to construction in other parts of the house. Is there any way of knowing what type of trap it is with such limited viewing ability?
HTML code is On
