Help with copper pipe size
Old 01-10-10, 08:14 PM
N
Hot water
Existing hot water copper pipe coming from water heater is 1/2". This supplies four fixtures: washing machine, bath sink, shower/tub, kitchen sink.
I am adding a basement bath and will need to add three more fixtures: utility sink, bath sink, shower.
I need to upgrade to 3/4" copper pipe from water heater correct?
Cold water
Pipe coming into the house is 3/4" until it reaches a reducer T.
The Pipe going to water heater is 3/4", but the rest of the pipe is 1/2".
Existing 1/2" cold pipe supplies water to five fixtures: washer, toilet, bath sink, shower, kitchen sink.
I need to add four more fixtures because of the basement bath: utility sink, bath sink, toilet, and shower.
Is it necessary to upgrade to 3/4" before they branch to each fixture?
Any guidelines will be helpful. I currently have nine lines total (hot & cold) with no problems with water pressure.
With the new basement bath and laundy reconfigure, I will be adding seven more lines (hot & cold).
Thanks!
Old 01-10-10, 10:46 PM
The golden rule is as follows:
3/4" from the main to the water heater, from there to the fixtures shall be 3/4" with branches down to 1/2".
3 on hot, 3 on cold when it comes to 1/2" pipe.
So as long as you bring 3/4" to this equation, you'll be in good shape.
HTML code is On
