Diver's putty
Old 02-03-10, 06:06 PM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Diver's putty
Where can I buy diver's putty online? A plumber gave me the last bag, and I don't know where he got it from. It's black, is like molding clay, stays pliable, seals exterior pipes and penetrations.
Old 02-03-10, 06:38 PM
F
Received 39 Upvotes on 31 Posts
I've never heard of diver's putty but what you describe sounds like duct seal. The duct seal I am most familiar with is a Johns-Manville product and it is grey, not black. There are other manufacturers of duct seal so try a Google.
You can probably also get it locally from an electrical supply house and sometimes even from the electrical section of the mega-mart homecenter.
Old 02-04-10, 02:47 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Well..not sure if its the same stuff, but same purpose I'm sure...we called it Monkey Ship ( not really..but you'll figure it out) and its what furd references. What I used to get was sort of a greenish color initially..though it kinda turned greyish black as it hardened and aged. http://www.computercablestore.com/Du..._PID43865.aspx
Old 02-04-10, 03:47 PM
XSleeper's Avatar
Thanks for the link- that stuff should work.
Old 02-04-10, 05:05 PM
5
HD sells the equivalent of what I always called monkey #$!$@. It is green and in a big rectangular block. They do call it duct sealant, and it is in the electrical dept'
Old 02-04-10, 08:31 PM
XSleeper's Avatar
Thanks, i will check next time I'm in there!
Old 02-04-10, 09:32 PM
ray2047's Avatar
One brand is Scotch electrical insulating putty. I have bought it at big box. You might tell the clerk it is for insulating split bolt connections.
Old 02-05-10, 12:28 AM
F
Duct seal is a completely different product than the Scotch insulating putty.
I've seen the duct seal in both white and greenish-grey. They both will turn sort of black if you knead it with dirty hands.
Old 02-05-10, 09:25 AM
ray2047's Avatar
Agreed but it was never established exactly what he had and it was black.
