Need help with strange shower valve
Old 02-16-10, 09:25 AM
Hi all -
I have a steam shower that has no hot water pressure. I strongly suspect the problem was caused by little plastic bits in the water supply caused by a defective cold water return in the hot water heater. I replaced the heater, but I think little bits are clogging the valve.
So, I turned off the water, pulled off the handle, and removed the outer sleeve that secured the assembly to the back of the shower. Below that I saw this type of cartridge:
Faucet Cartridge for Replacement A06 | Water Faucet Mixer Taps
The problem is that I can't figure out how to get it out. It is secured by a chrome dome shaped part with male threads at the back (used for the outer sleeve). How do I get this piece off? Pipe wrench with a cloth? Turn clockwise or counterclockwise? Is there another way?
Thanks in advance!
Old 02-16-10, 09:43 AM
My faucets came with instructions for removing/replacing the cartridge. Do you have the instructions for yours? If not, you can probably find them online.
Old 02-16-10, 10:12 AM
Nope - no manual - this is a Chinese steam shower with very poor documentation.
Old 02-16-10, 02:58 PM
shacko's Avatar
Question
It would have been better if you posted a picture of the problem faucet instead of what may be the cartridge.
Old 02-16-10, 03:39 PM
Good idea! Photos attached.
HTML code is On
