Sweat pipe corrosion? concern
Old 03-01-10, 08:43 AM
I noticed this on the hot water return to my gas boiler. Is this a concern? (see image)
Is there any way I should treat or clean it? The furnace was just installed maybe 5 years ago.
thanks for your feedback
Old 03-01-10, 02:00 PM
My guess is that the installer didn't wipe off the excess flux after soldering the joint. It won't hurt anything but you can wipe off what you can & even use steel wool or sandpaper if you want.
Old 03-01-10, 02:51 PM
Thanks for the reply Brad. My only concern is that I don't believe that was there a few months ago. is that a worry?
thx
Old 03-01-10, 04:18 PM
mickblock's Avatar
Once copper gets a patina (fancy word for corrosion) on the surface it ceases to oxidize any further. But like Brad had said, a chemical on the surface has caused the corrosion to accelerate.
It's not something that will compromise an already good connection.
Old 03-02-10, 04:43 AM
Thanks guys. I really appreciate the feedback. gonna clean that off later today. Cheers.
HTML code is On
