Only Warm Water at Kitchen Faucet
Old 05-03-10, 01:06 PM
Unhappy Only Warm Water at Kitchen Faucet
I just replaced the kitchen faucet because the handle broke, I was hoping it would magically fix my hot water issue as well. I was wrong.
Even after I let the hot water run for a couple minutes it only is luke-warm. I get plenty of hot water at other faucets in the house. I also set the new faucet to give me extreme hot and cold. Any help would be greatly appreciated.
New Faucet: Delta Kate Pulldown
Gas Water Heater
1500 Sq Ft House on Concrete Slab
Old 05-03-10, 06:10 PM
E
So you had that issue with the old faucet, the way it sounds. And you were hoping the new faucet would fix it.
You are going to have to see if water or hot water can flow good from the hot water shut-off valve under the sink.
Old 05-04-10, 08:11 AM
D
Just checking. You are getting good flow hot and cold, at the new faucet and other faucets in the house but when you run the hot water at the new faucet, the temp is only like 90 where as at the bathroom, the temp is like 120?
HTML code is On
