Repair leaking PVC pipe
PVC 3 inch waste line
Under full pressure (water test), there is a tiny leak. 1 drop of water every 1-2 minutes at one of the elbow joints. Short of ripping it out and redoing it, is there an alterative to repair it? Some special glue?
Thanks!
Thanks!
Well, we all know it should be done the right way. And the fact it drips at all leads one to wonder about the integrity of the glue job - perhaps not just at this joint, but at other joints. The glue was not old and congealed was it? But if this pipe is in an area that a few drops of water will not harm anything, you could -
-roughen up the joint with plumbers wet/dry emory cloth, then knead some epoxy stick, quicklly dry the spot, push on the epoxy you just kneaded (you can smooth it when still pliable, with wet fingers). Let dry for the required 6 minutes or so or til hard. Then as extra security, bandage the whole joint round and round (think 'mummy')with no less than electrical tape - or that special tape now they are selling on tv, being hawked by that one famous infomercial guy. (Seen the ad?)
Thanks for response. I decided to cut the whole pipe out and redo it. I used fresh glue (2 bottles) with a huge applicator this time and it is now fully water tight.
Thanks!
Thanks!
