Fixing a coupling
Fixing a coupling
Very new to plumbing. So help me if you can. Replacing a frost proof sillcock. I have the correct replacement. Got under the house and found the coupling.
When I put the new one on or took it off the coupling cracked and of course leaks. How does a do-it-yourself newbie fix this?
Also, I have the main water shutoff valve, should there be a valve that goes just to the sillcock so the water can be turned on for the rest of the house?
Thanks for the help
Thanks for the help
