Where do I buy self draining water supply valves
When I had a cabin in Big Bear, CA..the water supply valve on the house side of the meter was buried below the freeze line and was self draining when you turned the water off (and opened a faucet in the house). I'd like to buy one of these fr installation as the min supply valve for an irrigation system I'm getting ready to install. I haven't been able to find them on-line.. does anyone know what these valves are called, who makes them and where I might be able to purchase one (Lowes, HomeDepot don't carry them here in AZ).. I need a 1" valve. Thanks!
Believe what you are looking for is called a stop and waste valve. When you turn it off there is a weep hole in the side that allows the water between the valve and house to drain back eliminating the possibility of freezing and splitting. Any commercial plumbing supply house should carry them. You can find them in either female iron or compression connections. Check out the attached link:
Orbit Sprinkler System 1-Inch Brass Underground Stop & Waste Valve # (Orbit) - Reviews, Features, and Prices $60 - $61 at DealTime
I suspect the original poster was looking for an automatic drain that goes at the lowest point in an underground sprinkler system such as these:
Sprinkler System Watering - Valves
Or,
Champion Irrigation Products - DV-050 - 1/2in Automatic Drain Valve-Brass
I put one of the brass units in for my father-in-law some 25 years ago to drain a PVC pipe that ran down hill to a lower rose garden at his residence. I picked it up from a local homecenter and the cost back then was just a few dollars. I suggest looking in the irrigation / underground lawn sprinkler area.
Or,
