Old copper pipe fittings (repair or replace)
I am adding a basement bathroom and kitchen to my 60 year old house. The plumbing is all copper that I am cutting into to make my new runs. As I cut into the pipes at various locations I noticed that there was a lot of tension in the system that I assume was created by the house settling and flexing over the years. I had to relieve the tension in order to get the new joints to align properly. Upon reassembly and pressurizing the system I noticed a number of very minor drips on nearby fittings that I did not work on. I assume that this was due to relieving the tension and it effects on some joints. I still need to fix a few of these minor leaks but wanted to get some feedback before doing so. Here is my question:
Do old copper sweat joints deteriorate with age or are the minor drips just a result of relieving tension in the system?
I can simply re-solder the joints if tension is the cause. But if 60 year old joints deteriorate I should probably replace fittings while I have the ceiling open.
Thanks,
DavidJ
Thanks,
DavidJ
Copper Joints
With a house thats 60 plus years old it's a good chance the the pipe was put in with lead based solder; lead solder will deterioate over time to the point where you can pull the joints apart, you should replace all the joints, sorry.
I'll just throw in, it's really hard to resolder an old joint. Usually heating it just makes it worse as the joint needs to be cleaned and re-fluxed.
Thanks for the replies guys. I am just going to cut out the copper and replace as much as I can with pex. I have a Wirsbo expansion tool I used for my hot water heating system so it shouldn't be a huge effort. I also suspect that with the price of copper these days I am probably in for about the same costs if I go with Pex.
DAvidJ
DAvidJ
